PLS bear with me on this really dumb "overasked" q
pls tell me what the difference is between an LS1 and an LT1.
i'm looking to start a project with a second gen RX7 shell and would like to know what best to use(must be a chevy) just gatta have that v8!
most motors i've found at he wreckers are out of a 95camaro v8 and the same year firebird.
are these the same motors?
what is the power potential stock? as i'm on a budget
will is work with the fuel injection 'cos i'd like to keep it.
would any chevy shop be able to handle this project (cant do it myself)
pls again bear with me.
First, if you do a search in the Chevy v8 forum you'll find tons of information about this question. The main issue between the two is the mounts. The LS1 is newer and uses a different style of mounts. It seems the the 95 LT1 is the most popular since it has the vented Optispark distributor. Both the LS1 and LT1 are fuel injected. Power level for both is tied to you wallet.
Do a search and you find enough info to keep yourself busy for a week.
- Joe
