Guest 2slo4u Posted September 10, 2004 Share Posted September 10, 2004 I'm off Friday and Sunday, so I'm going one of those days. My car's not in great shape but I'm going to check my 1/4 mile. Never done it before (legally). Do they require helmets to run 1/4 mile? Brian 81zxturbo 95slobaru Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 10, 2004 Share Posted September 10, 2004 i might.. gotta see if i have the money to do so or the means to get there. they dont require a helmet not unless your faster then 12's.. (i think) but the inspection is BS and its a good track. mike Quote Link to comment Share on other sites More sharing options...
Guest 2slo4u Posted September 10, 2004 Share Posted September 10, 2004 Let me know, got my fire extinguisher ready. I'm going to relay the ignition coil and change the ignition relay and switch in the morning. I'm trying to solve the three crank when cold problem. Smells like it is getting plenty of fuel once it actually stays running so I'm wondering if the ignition is not getting good voltage for some reason when cold. If I get the relays in and the switch, I might go tomorrow, otherwise Sunday. Brian 81zxturbo Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 10, 2004 Share Posted September 10, 2004 i think im going tomorrow. going with some turbo and swapped honda guys.... gonna have to lower the boost down abit and fix my miss fire. think ill be there around 7. mike Quote Link to comment Share on other sites More sharing options...
240Z28 Posted September 10, 2004 Share Posted September 10, 2004 Nhra rules require a helmet for 12.99 and quicker so bring a helmet if you 're in the 12's to be safe. Quote Link to comment Share on other sites More sharing options...
Guest 2slo4u Posted September 10, 2004 Share Posted September 10, 2004 I don't even know if I'll make the 13's Brian 81zxturbo 95slobaru Quote Link to comment Share on other sites More sharing options...
Thumper Posted September 10, 2004 Share Posted September 10, 2004 Last time I went to houston raceway been a yr or two I had to wear a helmet in my 13 second car and in a convertible that was running 15's. I believe from track to track some rules vary alittle bit. So on the safe side if you plan to be in the 13's you might want to bring a helmet or you might get stuck with the crappy loaner ones. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 10, 2004 Share Posted September 10, 2004 ill bring one this time just incase for some reason tonight they make us (didnt last time) we can share.. so you coming? mike Quote Link to comment Share on other sites More sharing options...
Guest 2slo4u Posted September 10, 2004 Share Posted September 10, 2004 I'll be there. I couldn't find a helmet though. I modified my old crappy efi relay behind the battery to two new relays. Even though the contacts inside the stock relay were severely corroded, the new relays didn't make any running difference. Oh well, time to look for vaccum leaks again. I'll try to be there a little while before the track opens. Brian 81zxturbo 95slobaru Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 10, 2004 Share Posted September 10, 2004 what time does it open? i gotta go to the bank and fill up in gas. Quote Link to comment Share on other sites More sharing options...
