Guest 73TPIZ Posted September 19, 2004 Share Posted September 19, 2004 qwik240z, i found these to give some idea of the difference of mine and later shifters. This is what i have. 82-92 F-body. You can see the knot on the bottom i was talking about. This said '98 f-body. qwik240z, does this look like yours? They are different, but similar designs. Mine may actually be bulkier than the newer shifters, just by looking at the pics. Quote Link to comment Share on other sites More sharing options...
qwik240z Posted September 19, 2004 Share Posted September 19, 2004 Charles, Yes Mine does look just like the one you showed. Is yours shorter than the 98 shifter? I put mine on top of the trans tunnel and it seems like the handle will be way too tall. I have actually cut down some of the shifter frame so it can fit inside the tunnel and I was going to try to mount it from underneath the way Joey did in his LS1 280Z but I need to figure out how to seal off the hole in the tunnel and the stock lower shifter boot/gasket won't work. I know I can make something but I was hoping to use the stock boot. I have a boot from a 280ZX that seems larger but I need to pull it out of storage to try it on for size. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
