Guest JAMIE T Posted September 20, 2004 Share Posted September 20, 2004 I just spoke with Holley tech. He said basically I will need to make a crank trigger wheel, and use an MSD type ignition. The distributer will only need a cap and a rotor to scatter the spark. Hmm... I can do that! Quote Link to comment Share on other sites More sharing options...
Hugh Posted September 20, 2004 Share Posted September 20, 2004 So you're going to downgrade to a distributor type ignition? You can't run a waste spark with two coils? Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted September 21, 2004 Share Posted September 21, 2004 OK, so I've shown my ignorance. I did not know the SR20DET was distributor-less. My experiance has thus far been with SR20DE's mostly. I don't remember the GTi-R being distributer-less. I have no experiance with RWD SR's. Will the SR20DE distributor fit the S13-S14? FWIW, Holley tech did say that the Commander 950 could not be made to go distributor-less. humph... Quote Link to comment Share on other sites More sharing options...
Guest clay Posted September 21, 2004 Share Posted September 21, 2004 The Disco Potato will make the same or less power than a stock S14/S15 Silvia turbo. Thats a huge waste of money. Dyno sheets and pricetags have proven... its magazine hype. Nothing more. Yes, you can make the same peak Hp. The benifit to the DP turbo is supposedly in the response and actual usefulness of the power. If all you want is peak Hp, it's definitely not the turbo for you. That is why it is so hyped up among the FWD crowd. I have several friends that own this turbo and love it. In fact after a recent ride in a DP B13, my friend ordered one up to replace his T3/T04. It's also less fabrication to install as it fits onto a T3 flange and has an internal wastegate. Quote Link to comment Share on other sites More sharing options...
