Tony240ZT Posted September 18, 2004 Share Posted September 18, 2004 I just put a few things up in the classifies, they are directed at you Turbo people. Last time I had these throttle bodies you guys were fighting over them, so thought I should post here that I have two 65mm throttle bodies off of Mercedes V8's. If you are unfamiliar with them do a search for the topic. I have one of these throttle bodies mounted on my car: Link to ad: http://hybridz.org/nuke/modules.php?op=modload&name=zClassifieds&file=detail&cat=65&de=793 While I took a pic of the TB on my car I did an engine pic, haven't done one in a while: I am selling this car with the L28-ET very soon. It's a great car, but I need the money for the 7M-GTE project car. When I swapped out the L24-ET and put in the L28-ET I couldn't use my old oil adapter plate, so I have it up for sale. It has a T off of it to run an oil line to the turbo. Here is what the oil plate adapter looks like with a filter stuck on: You can see more pics under the classified: http://hybridz.org/nuke/modules.php?op=modload&name=zClassifieds&file=detail&cat=65&de=794 Here is a photo of the new oil adapter on the L28-ET, these were on automatic equiped 280ZX's I believe.. Perhaps only certain years? I re-used my oil lines so they were a little tight after getting a little cut, but turned out well. Also, I have a bare L28-ET block sitting in the garage. It has had the rough casting removed from the inside. It's prepped like "How to build your Nissan OHC engine" book tells you how. I had hoped to make a stroker engine out of it, but went with the 7M-GTE instead. At this point anyone is welcome to come pick it up for free. I have a front bumper off of a `73 240Z that I need to clear out too, and a couple sets of SU's in the garage.. Noticing these are turbo parts I'll stop there. However, I have been known to make SU's into something turbo related: Yes, this is what the orange car's engine compartment used to look like with a draw through turbo setup on a L24.. I could not get enough gas into this thing, and it would ping.. Caused the engine rings to get unhappy, that's why the L28-ET is now in the engine with fuel injection. The added fuel, intercooler, and t3/t4 turbo have helped the car get down the road faster now. Quote Link to comment Share on other sites More sharing options...
