dmanzo57 Posted September 25, 2004 Share Posted September 25, 2004 Here's an example... Don Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted September 25, 2004 Share Posted September 25, 2004 Sweet Don. Looks like that could keep you busy for a while Quote Link to comment Share on other sites More sharing options...
280zedx Posted December 18, 2004 Share Posted December 18, 2004 Is that a piece of real data? It seems to me your afr doesn't jive. why are you running so rich at cruise? and where is the lean spike when you got off the throttle after the wot to 5000rpm? please give more info. also - what kind of wideband setup did you use and how did you interface it? I've got the MS running well now and plan on upgrading to the MS&S over the winter. I also have a LM-1 (wideband reader) and want to get that AFR info onto the log viewer screen as well! Quote Link to comment Share on other sites More sharing options...
dmanzo57 Posted December 21, 2004 Author Share Posted December 21, 2004 The raw data is real, but the AFR data is not displayed quite right. This version of MSLVV was not configured to use the linear Vout from the Tech Edge WB unit. I've switched to a newer version, V2.2(I think), that lets you select from several different WB types. This data log shows it was very lean at cruise and spiked rich when I let off the throttle. I've got the linear output signal from the Tech Edge connected to the O2 input on the MS. I'm currently running the MSnS-Extra code which gives me a 12x12 fuel table and a 8x8 AFR target table. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 21, 2004 Share Posted December 21, 2004 Are you using the 020i9 extra code or just the 020i code? I am ready to switch over to the extra code and noticed both are in the download section, but the readme says to use the 020i9. Quote Link to comment Share on other sites More sharing options...
dmanzo57 Posted December 21, 2004 Author Share Posted December 21, 2004 I installed the Extra code about a month ago. I'll have to check the version when I get home. I'm running fuel only, for now. The readme says to get the 020i.zip file and update it with 020i9.s19. Don Quote Link to comment Share on other sites More sharing options...
dmanzo57 Posted December 22, 2004 Author Share Posted December 22, 2004 I've got version 020i dated 10/14/04. Don Quote Link to comment Share on other sites More sharing options...
