HELP RE: CAM WILL NOT COME OUT????
Guest zfan
ANY SUGGESTIONS WOULD BE APPRECIATED!!
I AM IN THE MIDDLE OF INSTALLING A EDLEBROCK
CAM IN MY 240Z. I HAVE DONE FIVE OR SIX SWAPS IN THE PAST WITH LITTLE OR NO TROUBLE BUT THIS STUBBORN BUGGER WILL NOT BUDGE AFTER ONE INCH OF REMOVAL? I DECIDED TO GO WITH THEIR CAM, WHY NOT I ALREADY HAVE THEIR HEADS,MANIFOLD AND CARB. WELL ANY GUESSES, TIPS, HINTS, DUMMY MISTAKES I MY PART???
IM ALL EARS!!!
Z/FAN...MIKE.
I agree with Frank, sounds like the fuel pump push rod is hanging on the first lobe.
Then again, if you did the JTR install, you wouldn't have a fuel pump there! ??
IF all the lifters are removed, and the distributor is out, I don't know what it could be besides a messed up or lose cam bearing, which I hope it isn't! BTW, is the oil pump drive shaft all the way down so it's not hanging on the cam? Maybe it got pulled up when the dirstributor came out?)
