Feel like taking a guess how much rwhp this setup will make?
Guest Magic
Hi all
I should have the following put together in about 2 weeks. We dont really have more than a handful of Turbo Zeds in Australia including the RB engines, anyone want to make a guess what will come out at the treads?
The winner will get bragging rights :D
P90 port matched and polished
Target CR is 8.5:1 (pending)
Flat top pistons.
t3/t4e
Internal wastegate - mechanical boost control (to start with anyway)
custom FMIC similar to sparco 2 1/4' outlets
Standard Turbo inlet/ exhaust manifolds + turbine all ceramic coated.
2.5" dump pipe
3" exhaust
370cc injectors + fuel pump to match
98 octane gas
Standard fuel pressure regulator.
Fully programable Autronic engine management (map sensor)
57mm throttle body
Stock L28e cam
Running through an R31 Skyline 5 speed gearbox (not sure what you call it in the US)
R180 3.9 diff.
Target boost 7psi for starterz then hopefully up to 15psi.
What do you reckon?
