Standard? GL? R200?!
Guest AShout4U
Guest AShout4U
Alright
I have a 1979 280ZX coupe NA 5 speed with power steering, power windows, power mirrors right. I looked underneath and i'm about 99 percent sure thats an R200 diff under there. Its stout as to how long and small the R180 is. But my car isnt a GL under the VIN number, theres no J. How can I be sure? Is there any way I can tell from the numbers stamped on the diff? I think it was like 347 or something and then the little hamburger thing was there.
Does anyone know how I can check for sure?
Everywhere i've looked my car "shouldnt" have an R200.
Well thanks for the help.
The pics above should make idenifing the difference between the two without a doubt, but one more way makes it easy also... Look at the side area where the halfshaft inserts into the diff, the R-180 will have a bolt on cover (oil seal area) with 6 or 8 bolts.
The R-200 will never have this. If you look at each halfshaft, toward the diff, and see bolts on the diff itself, (not the halfshaft) its not a R-200... 8)
