onephatz Posted October 12, 2004 Share Posted October 12, 2004 now I know it's not a z but it is it's close cousin. my '82 maxima 2.4L. I recently replaced the head gasket, cam shaft (with z cam),two leaky injectors, and the oxygen sensor. she ran smooth and good before the tear down. now (see below) problem: idling seems ok but does not rev up well(sounds like a miss) and wants to backfire thru the intake manifold. will not pull it's self down the road with the same problems as above checked: fuel pressure ok (32-40psi) tps ok (idle and wot) afm ok (proper resistances) injectors working (checked each with a screw driver) can't find any vacume leaks ignition is set to stock 8 deg btdc adjusted the valves to proper tolerances ignition primary's and secondary's working great (checked with scope) compression good on all cyl. ~175psi each interesting point: when the injector plug on the #1 cyl is removed you can hear a small difference in the engine but not as much as with the other cylinders. I can definatly hear the injector firing but no difference when unpluged. I am kinda at my wits end right now so any ideas would be very welcome thanks jesse Quote Link to comment Share on other sites More sharing options...
onephatz Posted October 12, 2004 Author Share Posted October 12, 2004 well as it turned out the crank pully turned on the harmonic balancer and was throwing off my timing. my dad(mechanic of 30+year) show me the "old way" of setting the timing with a vacume gauge. he said that at idle there should be about 20-21 inches of vacume. I was setting at ~15. cranked the distributor around and she smoothed out, and reved good. jesse Quote Link to comment Share on other sites More sharing options...
