AN fitting Guru's help please
can anyone help me out with where to obtain some -19, -20 or larger male alum fittings so I can have them welded onto my alum radiator ?? I want to use AN line/fittings to connect my upper and lower water hoses.
They make -19 and -20 reuseable female hose ends, because I have a couple, its just that I can't find the male nipple anywhere to have welded onto the radiator... ANYONE ??
thanks
j.
Sure.. try looking here:
http://store.summitracing.com/default.asp?target=eproduct.asp&N=120+400027+309148
Meziere Enterprises also makes some other neat AN fittings as well that are listed at summit.
RPMnet also lists a -20 AN Weld-On here:
http://www.secureperformanceorder.com/onlinestore/getproduct.cfm?CategoryID=6&ClassID=66&SubclassID=1235&ProductID=6429
Hope this helps
