Earl's Super Stock hose?
wheelman
I'm getting ready to purchase fuel line to feed the LT1 and I'm a little over whelmed by all the options. I'm replacing all the lines and have already purchased a Walbro GSL392 pump so that much is determined but I don't want to spend a fortune on the stainless braided stuff.
I've almost decided to use Earl's Super Stock line with appropriate hose ends but have no experience with it.
What do you guys think?
Do any of you have experience with the Super Stock hose and fittings?
The other option I'm considering is 3/8 aluminum tube with appropriate adapters so I can connect to the pump, filter and sump on my tank which has male -6 AN fittings. This setup requires more adapters and I still need to use some flexible line for parts of it.
Also does the Walbro pump need to be mounted below the tank outlet or will it pull a siphon on it's own?
Wheelman
