Centerforce clutch II question
Jonas240z
Hello there;
I need some urgent help please! I have a 280zx 5spd tranny and I recently purchased a centerforce clutch II, because i'm going to use a 13.5 pound flywheel. My question is: do i have to use a clutch collar (2 1/16" length )from a 280z in order for this set up to work? :? I have the collar from the 240z ( 1 3/4" length )wich worked with the current clutch (stock) and the 280zx tranny, would i be able to use it with the centerforce clutch???
I believe you are correct. The 240Z collar will not work. When I did my 5 speed (late model) conversion I took the collar that was with it. My 5 spd came out of a 280ZX non-turbo car. I also choose a Centerforce II clutch assy for my 1970 240Z (with L28/SU's). However, internally my engine is stock so the clutch doesn't see alot of HP. It's all been working perfectly for me since I put the car back on the road in 2002.
