master cyl prob
Guest dwinthrup
Guest dwinthrup
i just got my 280z last week and the brakes were so stiff when i got it. the car wouldn't stop. the booster line from the intake manifold was diconnected and pluged. so i blead them and hooked the line upand now they go right to the floor and the car don't stop. any ideas
Someone may have pulled the MC and had the reaction disk in the booster fall out. I chased my tail trying to fix my brakes and ended up replacing everything except the booster and they still didn't work. I replaced the booster and found that the disk had indeed fallen out.
If the shaft on the booster is pulled away then the disk will fall. If you get a new booster they have a paper holder on it to keep it in place. Dont remove it until your ready to install the MC on it.
Good luck and hope this helps,
