Guest Anonymous Posted February 3, 2003 Share Posted February 3, 2003 I have a small block Chevy in a vehicle right now (87 Trans Am) that I can't see the casting #, but the stamped number up front is K0824FJC. Does anyone know what engine this is? The car came with a 305, but I suspect the short block may have been changed (has centerbolt heads and all other accesories look original, or at least correct for a carbed 305). Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted February 3, 2003 Share Posted February 3, 2003 Joe, The numbers up front on the passenger side of the block near the alternator are the engine assembly date and suffix code. I went to this site: http://www.mortec.com/locatpg2.htm and came up with the following: K= Engine Factory location (McKinnon Factory Canada) 08= Month (August) 24= Day of month (Aug. 24) FJC= Suffix Code I could not find what the suffix code on your car was but that info is out there somewhere because I was able to figure out what mine was a few months ago. You will need to get at the casting #'s to see if your block is a 305 or 350. Hope this info helps ya out. Quote Link to comment Share on other sites More sharing options...
