4G63 Turbo swap in a 240Z??
Guest dhart-cc
Guest dhart-cc
Just wondering if anyone has or has tried putting an 4g63 turbo (eclipes, talon, laser) engine in a 240Z??? with a rear wheel drive setup, possible T-5 tranny setup??
Any replies are apprieated
Thanks
I imagine that swap would be pretty interesting, provided you dont mind looking around for a couple parts aside from your 4g motor setup.
There are a couple ways to do this, but this one seems easiest to me:
You'll need a 'W' or 'G' VIN Mitsubishi Mighty Max block (dependent on having a 6 bolt or 7 bolt motor), which allows a bolt up installation of a Starion/Conquest 5 speed transmission, and sets you up for a rear drive setup. The mighty max block is a 2.4 liter tall deck design, but your 2.0 4g head should work just fine. This setup has a longer stroke than the 2.0, and if memory serves, uses the same rod length due to the taller deck.
IMHO, that would be a pretty wicked swap, and would be great if you already have a 4g setup laying around the house. :twisted:
