need help adjusting idle
Guest xbangu
This is what going on, I have 240Z with a turbo engine.
My idle can set it at range from 0.9 to 1.7
note: using the idle screws one on the manifold and the other in the AFM doesnt seem to help at all. Only increase, but hardly go down.
(adjusting the AFM itself)
At idling 0.9, when driving i can go pass 3.0rpm at any gears
if it's at 1.3-1.4 I can go up to like 3.6-3.7rpm
if at 1.5-1.7 i can go you to 4.5rpm
have anyone been in this situation before???
  • 4 weeks later...
This is what I did so far to try to get my car idle correctly.
1. Replace with a known working AFM
2. Replace ECU
3. Replace all the holes on the manifold.
.....still no luck..... anyone here ahave any other suggestion and does anyone hin here know a Z expert shop near by so I can take my car there.....
thanks
