SU carb fuel questions
Guest 83supaZ
Guest 83supaZ
what do i need to do to connect my su carb setup to my 83 l28e.. i have the intake.. just need to know what lines go where as there are 2 small connectors.. and one large connecter on the intake and one on each outside of the carbs... anyone have any pics of a SU setup?? or know where i could find a diagram of fuel delivery for SU carbs
http://hybridz.org/nuke/modules.php?op=modload&name=coppermine&file=displayimage&album=180&cat=0&pos=1 Thats not a great pic, but hopefully will give you an idea. I took off my FI and put those SU's on. .. you might run into problems with the carb intake bolt holes not lining up with your head.. If so, I'll give you more info if you need it..
As it says, I had to 'pinch' off the return line.. The FI lines are TOO BIG trust me. You need to get the 240/260 fuel lines (easiest) or adapt something so the line that feeds the carbs is smaller. On the 'outside' of the carbs, those are just float bowl vents. I just left mine like they are (no hose conected or anythin) and its fine. The other two (off each carb) are the fuel lines. And the big conection on the intake will be for the PCV, from the front of the engine block.. you'll see it once the FI intake comes off. Hope this helps. :-D
