Guest bigjim240z Posted February 3, 2003 Share Posted February 3, 2003 ok..going to be ordering some heads for a freinds motor that im hopping up a little..i planned on getting the performer rpm heads...but i was looking at the summit catolog and saw some trick flow 23deg heads that claim better hp numbers...it also says that special push rods will be needed...why?..and will i be able to use the edelbrock rpm intake?..thanks for any help..i planned on buying the whole edelbrock performer rpm package..heads, intake, cam...but im thinking different now..but still not set on what to get..thanks for any help. Quote Link to comment Share on other sites More sharing options...
pparaska Posted February 3, 2003 Share Posted February 3, 2003 I think the Trick Flow heads are a better bang for your buck than the Edelbrocks, at least the older design. I have no idea what the newer designed Edelbrock heads are like - haven't seen any independent flow or dyno tests of them. But then again, so are the "Jeg's" heads a good bang for the buck. They are actually Canfield heads and flow well, have a good combustion chamber design, and are well made. Your favorite Grumpyvette likes these, BTW. Quote Link to comment Share on other sites More sharing options...
Zfreak Posted February 4, 2003 Share Posted February 4, 2003 Is your friends motor going to make hp on the top of the rpm curve or in the mid range? Edelbrock is fine for a lower reving motor. If you really want to wind it up go with the Trick flow or ever better Airflow Research. Quote Link to comment Share on other sites More sharing options...
Guest bigjim240z Posted February 4, 2003 Share Posted February 4, 2003 well he wants 400 plus horse power..and it will be in a 240z with either a t56 or wc t5...i wouldent think it would need major low end torque in a 240z..so maybe the trick flow's are the right choice...whats the reason for the special push rods with the trick flows?..any one know?..thanks jim Quote Link to comment Share on other sites More sharing options...
jt1 Posted February 4, 2003 Share Posted February 4, 2003 The Trick Flow twisted wedge heads require odd lenght pushrods to get the valvetrain geometry right. I learned that the hard way. I don't know if that's still the case or not with the newer heads. Why don't you call Trick Flow, everytime I've called them they've been very helpful. John Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted February 7, 2003 Share Posted February 7, 2003 If TF's are angle plug make sure you understand your header solutions if that might be an issue. FWIW, my RPM's have been very good to me...their OEM springs aren't so hot but I replaced them a few years back and no issues with the comp cams replacement parts I used. I run a Victor Jr. and on both my 327 and my 350 they shredded tires right off of idle with no preload etc and mild cams. Just my .02c. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 9, 2003 Share Posted February 9, 2003 Go to www.chevyhiperformance.com/ they have all the heads flow test in their site. Good info! Quote Link to comment Share on other sites More sharing options...
