Guest epiman500 Posted November 1, 2004 Share Posted November 1, 2004 I have a 71 240z, i have been trying to install the koni 86-1811 strut inserts. as far as i have been told they drop right in,,,wrong, it works out that the koi=nis are about a 1/4 inch to long for my strut housing. the id of the housing is about 15inch, from top lip to the bottom. has any out there =ever check the id ???? i just got the car and the years werent good to it looks like alot of wanta be racers might have played with it . i cant find anyone that knows what the stock id is/ was.......helppppppp Quote Link to comment Share on other sites More sharing options...
johnc Posted November 1, 2004 Share Posted November 1, 2004 Are you trying to install the double adjustable Koni 8611 or the single adjustable 8610? If you're doing the 8611, which part number (there are three different 8611s)? If you're installing the 8610s, here's a writeup: http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=25481 FYI... I've measured the stock ID of the 240Z strut tubes at 1.70" +/- .010" depending on the level of corrosion, damage, etc. You will have to ream the ID to fit pretty much any of the 8611 double adjustables. The 8611 that best fits the travel requirements of the 240Z is the 8611-1256 but its OD is 1.79" You will have to take .010" off the inside of the strut tube and clean up any welding you do after shortening to get those units to fit. Quote Link to comment Share on other sites More sharing options...
Guest epiman500 Posted November 1, 2004 Share Posted November 1, 2004 I am trying to install the 86-1811 inserts, I gota tell you all that , i got blind sided by koni, today they said" jut send us your housing and the new inserts and we will figure it out and install them free and pay for the shipping back. i didnt see that comin,,,, but i still dont know why the inserts dont fit, ?????? Quote Link to comment Share on other sites More sharing options...
johnc Posted November 1, 2004 Share Posted November 1, 2004 but i still dont know why the inserts dont fit, ?????? Oops, sorry. I forgot about the 86-1811 stock replacement inserts. Are they still available new from Koni? When inserts are installed correctly they do stick out about 1/8" from the top of the tube. The gland packing nut is supposed to tighten down against the insert, not the strut tube. Quote Link to comment Share on other sites More sharing options...
Guest epiman500 Posted November 1, 2004 Share Posted November 1, 2004 yes you can still get them, but on mine you can only get about hafe a thread started. Quote Link to comment Share on other sites More sharing options...
