cheezmonta Posted November 7, 2004 Share Posted November 7, 2004 I have a NISMO 2-way VLSD installed in my car right now and have run into a bit of a problem. The LSD was installed in my 89' (Z31) N/A R200, replacing the open diff. There is about a mm of freeplay in the input when they are installed. I nabbed a turbo axle from my friend to see if that would work but it is the same diff. input as the stock ones on the car. The axle was from an auto turbo. May be differant from the other turbo axles, I'm not sure. I need some insite as I've been racking my brain on this one for a week. Are the MT turbo axles input shaft bigger than the N/A. What about the Shiro axles? Would a set of these work better since they are from a VLSD stock? Quote Link to comment Share on other sites More sharing options...
WickedWild Posted November 8, 2004 Share Posted November 8, 2004 I beleave that there are two different sized R200 open rear ends, I just wish I could remember what the differance was. If I'm on the right track and you need the latter of the two, I have a spare from a n/a '85 300zx with the too wide cv half shafts (accually I have the entire rear and front crossmembers disk to disk). If you need any of it pm me. Quote Link to comment Share on other sites More sharing options...
cheezmonta Posted November 10, 2004 Author Share Posted November 10, 2004 I need these measurments to see if they would fit. This is a crappily made diagram of my NA axle. I'll need the Dia. and length of the input. I have the "A" arms for both type of boltup to the hub so no problems there. Hope this pic works. Thanks Quote Link to comment Share on other sites More sharing options...
