difference between L28 turbo dizzy and VG30 dizzy?
PhaTTy
Does anybody know what the differences are between the 84-89 300zx distributor and the 83 280ZXT distributor? All I need to know is if they both rotate the same direction and if they send the same signal for the crank sensor.
Thanks!
P.S. - My dilema is I have a Microtech LTX-8 being programmed right now and the engineer needs to know whether to program the crank sensor input for a VG distributor or a L28ET distributor. I am using a 83 L28ET distributor with 84-89 300zx electronics in it and the pickup disc/wheel from the 300zx in it. Wouldn't this essentially make it a VG distributor then?
Thanks!
Yep it's the same signal as the vg distributor. I have some scope shots of the signal if you want/need to send them over to them.
Bernard
