Guest Gillez260ZT Posted November 25, 2004 Share Posted November 25, 2004 Hi everyone, I have just completed an Electromotive TEC2 installation on my 280ZX turbo- powered 260Z. I'm running a Garrett T04 (was there before the TEC2) and need some bigger capacity fuel injectors. The ones I had turned out to be bad and unrepairable (no wonder the guy gave them to me when I bought some other parts!) so I need to find something else. My fuel rail has barbed fittings so I need something like the original ZX turbo injectors with a hose or a barbed fitting on the fuel rail side and a tip that is also like the stock injectors on the manifold side. I'm looking for a flow rate of around 450cc, give or take a little. I know Kinsler injection has something that would be a perfect fit (I've e-mailed them for a quote), can anyone recommend me something from a nother car that would fit or another supplier of new injectors? Thanks in advance, Gilles Lajoie Quote Link to comment Share on other sites More sharing options...
Bernardd Posted November 25, 2004 Share Posted November 25, 2004 Sticky in the turbo/supercharger section. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted December 15, 2004 Share Posted December 15, 2004 mercedes 4.5l v8 made in middle 70's .or a late model mercury 2.5l efi outboard.if you go cheap you will regret it.get a new set or if you get usd injectors have them flow tested.i lean injector will melt a piston quick.when you start making 2hp/ci you dont get much time for correcting mistakes.i think a company called brucatto sells them at reasonable price for merc outboard engines.i had a boat with a merc 2.5.it was real fast Quote Link to comment Share on other sites More sharing options...
