I need some heater solving help.
Guest iskone
Um.. just curious.. why did you put your dizzy on that side of the engine?!? :lol: nice custom work anyway... Um.. could you get/build a 'T' fittng of some sort and tee into the rad hose perhaps? (you may even find something in a wreckers.. I'm sure i've seen somthing like this with a temp sensor in it..you'de just have to drill ithat out and attach a hose.) Then run/jog the smaller dia. heater hose around your dizzy and other obstructions to the firewall...
My car has no heater because the distributor is where the hoses sould go.
Actually, I don't think it is. The heater hose usually connects to a hose barb that points straight back, and is located at the base of the water pump inlet at the engine. Here's a not so great pic of mine (I'm using AN fittings, but you should be able to see the orientation)...
It looks like you just have a pipe plug in that fitting right now. Pull the plug, get a hose barb in there and hook it up.
