TRANY SPEEDO GEARS
Guest HIGHRPM
Guest HIGHRPM
Hi guys. I've tried the search engine, but came up blank. I just got my wifes 260 on the road and did a speedo test against another car. I expected it to be out, due to different tires and trany. The puzzuling part is that as the speed doubles, so does the sread in speed readings. At 30 mph it is 5 mph slow, but at 60 it is 10 mph slow. I'm thinking that the trany gear is wrong and that the head unit is also flawed. I would like to change the trany output gear, but can't find any info on whats available. Any help here is greatly appreciated. I need my wife off my back, so I can work on my 260. Thanks for your time.
Rod :cool:2thumbs.gif
Guest greimann
What you perceive as puzzling is actually perfectly normal. When a speedo has the wrong gearing, the indicated reading is going to be a percentage off of the actual speed, not a fixed number of MPH. 25 indicated at 30 actual, and 50 indicated at 60 actual, calculate to 16.66% under driven speedo gears. You need to find a driven gear that has fewer teeth, so it spins faster. I don't know much about Z transmissions, so you will need other help from here.
from some of the archives I saved on my system, can't remember where this is from, but i think it's from jeromio's page
Speedo Gearing Info for the Tranny
Per Datsun Garage
YELLOW is the 16 tooth for the 3.36
BLACK is the 17 tooth for the 3.54
BLUE is the 18 tooth for the 3.70
WHITE is the 19 tooth for the 3.90
RED is the 20 tooth for the 4.11
PURPLE is the 21 tooth for the 4.38
Per Zhome List
Here's Michael's data:
3.36 : Yellow
3.545 : Black
3.7 : Blue
3.9 : White
4.11 : Red
Guest HIGHRPM
Per Datsun Garage
Per Zhome List
3.36 : Yellow
3.545 : Black
3.7 : Blue
3.9 : White
4.11 : Red
Ask a question, get great answers and an education to boot !! Thanks for the respoce guys, greatly appreciated.
ROD
