ratedZ Posted May 20, 2002 Share Posted May 20, 2002 I want to clean out my engine with a degreaser etc. BUT I'm very affraid to do so. I did just this last year and my TPS went out of wack and I had to replace it. The engine bay was very clean though and my engine is now in need of cleaning once again. I cleaned some things by hand but it takes a very long time and my back is killing me. So what should I do before I wash out the engine? I know I need to cover the TPS switch, K&N filter and the alternator with plastic bags. Am I missing anything else? Also, can I use a regular garden hose to do this or should I use a high pressure washer? Thanks all for the tips. PS. any recommendation on good degreasers in a can? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 20, 2002 Share Posted May 20, 2002 Rated, Yeah, I would just cover it with a plastic bag so that it's not getting blasted by the water. I found a product at Costco called 'Oil Eater' which works very well. Comes in a 1 gallon jug with a squirt bottle. I usually let this soak on the motor for 10-15 minutes, then rinse with simple green, then with water (hot). Always does the trick for me. Tim Quote Link to comment Share on other sites More sharing options...
