violacleff Posted December 31, 2004 Share Posted December 31, 2004 First of all I apologize if this thread is out of place, but there are so many options I'm not sure where it would go, but since most guys here have an l28et....... My last thread discussed some of my prior problems which I have worked out I believe. I'm finally getting spark and when I turn the motor I am getting a "Put Put.....Put Put PUt" sound and can smell exhaust (no exhaust hooked up yet). Now here's the deal. My origina setup was going to consist of a Z31ECU, E-manage piggyback fuel management, and RC 500cc injectors. The going concensus has been that a piggy back is a bad idea. So I was trying to see if the car would fire (I knew it would not idle) with those injectors since I don't have stock ones, just to see if the car worked and was wired properly. Well the car didn't completely fire I just got the reaction that I mentioned above. Should the car have at least fired or is this what should have happened with such large injectors? and am I just a set of stock injectors away from the car running? If so, my next question is.... Since I cannot yet afford a stand alone system I was just going to buy a set of stock injectors and run stock boost until I get a haltech. However I have a huge T4, and was concerned whether or not I would have enough fuel out of stock injectors. I figured it shouldn't be a biggie as long as I'm running stock boost (6-7 psi). Is this ok? Or will it run lean regardless? Quote Link to comment Share on other sites More sharing options...
