fuel pump voltage in "ON" position
260ZRED
when the key is on, Im getting 4.45 volts through to the fuel pump, but when the engine is cranking, Im getting a full 12.6 volts. (battery is a bit low) Is this normal?? Im not running the fuel modulator, and the wiring does not have proper soldered connectors yet. Engine is L28ET, 1982. Running the stock EFI and Fuel pump relays. Why woul dit not give me 12 volts when in on position??????
thanks for any help or info about this.
