stagefumer11 Posted January 14, 2005 Share Posted January 14, 2005 When using .8 gap on my Ngk's Bp5ey's at 10psi my spark gets blowen out. Now ive gaped them to .6 and it ran to 18psi fine (as a test)....... Now id presume this is to weak of spark?, i have a Nice Bosh GT40R Coil, new leads plugs. Now i cannot get a new Dizzy cap and rotor which i guess i badly need. Would also bad grounding to the block cause this ? Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted January 18, 2005 Share Posted January 18, 2005 Are you running a resistor between the coil and dizzy? If you are, that would weaken your spark dramatically. Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted January 20, 2005 Share Posted January 20, 2005 Do not underestimate the value of a good grounding. This is the first thing I'd check. You mention it as though you suspect it. Quote Link to comment Share on other sites More sharing options...
Guest billyzbear Posted January 26, 2005 Share Posted January 26, 2005 I hope I'm reading your post wrong. .6 gap is large and .8 gap is very large. Should be around .44. I don't know your year, make and model. What dist. are you useing? Have you checked voltage at coil? Points or air gap? You mite want to look at Crane HI-6 or MSD 6a. Get good wires that have a solid steel core, 8 or 9 mm. Quote Link to comment Share on other sites More sharing options...
