Autometer Speedometer installed.
DaleMX
Well I finished the speedometer yesterday. I drilled a hole in the plastic bezel then used a section of aluminum tubing and some heat shrink tubing to extend the trip odometer button. The glare in the picture makes all the bezel scratches stand out really bad, but in true life you never see them. The high beam light will be placed behind the screw that holds the housing in, right in front of the plastic. I hope it does not glare on the bezel. If it does I’ll move it inside the plastic.
http://www.circuitflex.com/Speedo1.jpg
http://www.circuitflex.com/Speedo2.jpg
