Transmission Suggestions
Guest rubbercow
Guest rubbercow
I am currently running a beater 4spd manual on my SBF Z. What transmissions are everyone else using, what is suggested and what is involved in attaching the preferred transmission (adapter plates, etc)?
Thanks.
Is that the same type bell housing that was used in the 94-95 cobras? It seems that I heard somewhere about a different bell housing during those years.
I used a World Class T-5 (which happened to be in my '86 donor car) and the JTR crossmember, hardest part was making blocks that follow the contour of the floorpan. Where my trans mount bolts up, the floor is not even.
Someone used the stock crossmember and bolted/welded new mounting points to the trans tunnel. I would have went that route if I hadn't already had my "blocks" welded up and drilled out. It was a good idea, hopefully someone else will remember who it was.
Mark
