Guest chrisDCruz Posted January 17, 2005 Share Posted January 17, 2005 Is it possible to convert a 240z automatic transmission to manual trans.? If so, is it easy or a lot of work? How is the price range? Quote Link to comment Share on other sites More sharing options...
GabeRoc Posted January 18, 2005 Share Posted January 18, 2005 Is it possible to convert a 240z automatic transmission to manual trans.? If so, is it easy or a lot of work? How is the price range? if you are asking if you can somehow alter your current automatic transmission to a stick shift, the answer is no. if you are asking if you can buy a manual transmission and swap it out for your current auto, the answer is yes. assuming you meant the latter, the swap is only slightly more difficult than a normal transmission removal and reinstallation. prices... i'm not sure what an decent manual transmission for a z typically cost, other than that you will need a flywheel, clutch and pressure plate, clutch master and slave cylinder + hydraulic hose, different driveshaft, a clutch pedal assembly for inside the car and an interior consol made for a manual. that should be all the major parts needed for that swap, there will be at least a couple of 'small' items that will also might be needed, but there always are. hope this helps answer you question, gabe PS for future referance, this topic is more for fixing car problems. transmission questions are generally dealt with under the engine section. Quote Link to comment Share on other sites More sharing options...
Guest chrisDCruz Posted January 18, 2005 Share Posted January 18, 2005 Thanks you very much gabe! Quote Link to comment Share on other sites More sharing options...
