ITBs and.... and, stuff...
Hashi
Guys... is there, by any chance, an individual throttle body setup for an L28e? What about a supercharger? If so... I think I just found my new goal... if not, I found an L28et that includes the full engine(turbo and all), tranny, ECU, and harness for like $700, but I think I can get it for $600. Mmm... think of those ITBs singing...
hashi,
ITB's are generaly an N/A thing. If you buy a turbo motor, you will have a low compression ratio, somewhere in the 7:1 range iirc. If you are planning to run it with the ITB's in N/A form it will be slow because of the CR... The turbo block is a good building point regardless, so If you throw some flat tops in there, or flat tops and an N42 head, then your cr will be up and N/A will actualy be fun. Otherwise get the turbo motor, leave the turbo on it, and run it till it dies!
-Oliver
