weakest link
Guest StreetVelocityGTR
what would you say the weakest part is on the rb26 i know the pistons give out at 600 but what about valvetrain how high can you rev before the lifters go
Pistons, rods, oil pump, crank, block; in that order. No problems with the valve train when upgraded properly. Step 1 cams require no mods but benefit from springs, step 2 cams require springs, etc. There is no sense in reving a motor with the stock cams higher than stock. There is no additional benefit to this.
thanks whats a good website that just has genral information on the rb that tells things like stock rev limit and stuff like that thanks
