driveline help
Guest Ballistic
Guest Ballistic
i have a 1993 NA with a 1 piece driveshaft
i have a 1990 twin turbo thats been wrecked in the back
i have a 1993 Q45 thats been wrecked in the side
i would like to enter the Silverstate Classic in 2006.can anyone give me any info on the 93 Q's rear diff?is it the R200 or 230?if its the 200,am i correct to assume that the driveshaft from the NA will bolt right up?if its the 230,then will the TT driveshaft bolt up?
i need to know in order to determine which tranny i will use.thanks in advance
Ballistic, You are likely not getting a responce......because:
With just the slightest amount of effort, you can do a search in the archives here or on the open net. We don't mean to be rude by not responding, but we see many questions asked by newer members that only require a little thought and effort to research out an answer. It's actually worth the effort to learn to use this function, as you will discover many, many things about the Z car and a variety of possible modifications that can and have been done.
