Chaparral2f Posted February 11, 2005 Share Posted February 11, 2005 I've used the search function all morning, and found nothing. So i guess i have to ask. Is there an in tank fuel pump that will feed my carbed 350? I know that GM used in tank pumps on fuel injected engines but I was wondering if they used one on a carbed one. if so, what year will work? Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted February 12, 2005 Share Posted February 12, 2005 I'm confused. Why do you want an in tank pump? I got an external pump for my carbed motor in my Z. It is sitting in the old fuel pump spot. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted February 12, 2005 Share Posted February 12, 2005 Same with me. LARRY Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted February 12, 2005 Share Posted February 12, 2005 I agree with Tony. Granted I'm running a LS1. But... The stock location works great. To answer your question? Yes! T.B.I G.M. motors used a low pressure, intake pump. I believe around 13 to 15 p.s.i. Now adapting it to a datsun tank would be some work. I really don't see an advantage. Hope this helps! JOEY Quote Link to comment Share on other sites More sharing options...
Chaparral2f Posted February 12, 2005 Author Share Posted February 12, 2005 OK, here's the explanation. I've got a Z31. and the 300ZX had an intank pump. I didn't think that a stock Nissan pump would be able to feed the chevy. A while back when I moved the gas filler to behind the licence plate I plumbed the tank to feed a Holly red Pump from the bottom of the tank. This works alright as far as fuel delivery goes, but I am really uncomfortable with the fitting on the bottom of the tank. Not only does the fitting seem very close to the ground, but there isn't very much room for the ext fuel pump. Quote Link to comment Share on other sites More sharing options...
