Looking for updated info on PS for 280Z
Guest ScarabZEE
Guest ScarabZEE
I've done the search on power steering for a early Z car here on the forums and didn't really find anything conclusive and was hoping that someone has come up with a good conversion to power steering. Does the WRX steering rack work and if so how is it done on a 280Z ?
I've just purchased a 2002 WRX rack for my 71 240Z conversion. The swap looks very doable without too many modifications. The original 2.4L is still under the hood. As such, could anyone tell me what PS pump (and remote reservoir, if applicable) and bracketry that is a direct bolt-on to the 2.4L straight six? How about required pulley(s)?The hoses are not an issue as these can be fabricated to adapt pump to rack. I know others are comtemplating this too and find info sporatically throughout the forum. It seems that many subjects get sidetracked with superlative commentary or hijacked and spin off on another subject entirely....just an observation, mind you.
Guest ScarabZEE
Thanks guys, I knew someone here would know something about it.
Jake did you do it yourself? Is the rack the exact same lengh and do you need to change the tie rod ends or anything?
Guest bswanstrom
Anyone have a difinitive answer on the best tie-rod ends to use? I see people talk about the ZX ends, shortening the 240's, all kinds of solutions - Seems as there are almost too many ways to do it....
Guest ScarabZEE
Well I just got my WRX PS rack out of a 2003 and all looks well but haven't figured out what PS pump to use with the WRX PS rack. Guys I'm gonna do this and I'll take pictures along the way, once the weather changes. If anyone comes up with a good Idea let me know.
