~Need Help With Wiring~
Guest tony78_280z
My adivice, dont get ahead of yourself and make mistakes. I waited until the motor was in to trim much of it back. It was much easier that way. I then knew what I needed and what I didn't. Be patient, it is best to be damn sure you wont be rewiring something. Oh and get like 6 rolls of electrical tape. =)
Thats just way too broad of a questions. Wiring is one thing that is way to hard to explain what you need and what you dont need over the internet. I would do just what Tony said and install the engine and then decided what you need and dont need. It really depends on how much of the stock sensor you will be using.
I went though the harness in my 280ZX while the engine was out but I can read wiring diagrams pretty good so I eliminated about 75% of the stuff I knew I wasn't going to need before I installed the new engine. I still had to go back over it once the new engine was in and eliminate more. I guess if your not sure then you should just leave it be for now untill the new engine is in and then start cutting.
Guy
