Guest 83supaZ Posted February 20, 2005 Share Posted February 20, 2005 what was the driveshaft adapter called? a nepco adapter? also what exactly comes with the adapter? does it adapt your chevy driveshaft to mate to the zx rear? i know this has been asked before.. i just dont know how to spell the adapters name... Quote Link to comment Share on other sites More sharing options...
Psykovertible Posted February 20, 2005 Share Posted February 20, 2005 can't remember spelling either but i believe it is NEAPCO. The phone number to a vendor here in phx az is 602-258-2552. the part number is 2-2-899. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted February 20, 2005 Share Posted February 20, 2005 JTR calls it an adapter flange. The one they sell fits R180's & R200's with a 2 1/4" pilot hole. These diffs came in both the Z and 280ZX's Neapco, I believe is the name of company that also sells this part. Quote Link to comment Share on other sites More sharing options...
Guest 83supaZ Posted February 21, 2005 Share Posted February 21, 2005 does it get welded onto your chevy driveshaft? or does it bolt on somehow? Quote Link to comment Share on other sites More sharing options...
Psykovertible Posted February 21, 2005 Share Posted February 21, 2005 you install the adaptor flange onto the driveshaft with the u-joint. so a flange is welded to drive shaft permantly, then the u-joint installed, then the adapt flange installed onto u joint, then it bolts to diff Quote Link to comment Share on other sites More sharing options...
pparaska Posted February 21, 2005 Share Posted February 21, 2005 Check these threads. ALL the info on driveshaft adapters for the R200 you could want. There are about 5 Neapco/Spicer/Dana parts that work. The part number through each of the Neapco/Spicer/Dana catalogs I believe are the same, for the same parts. Someone needs to take these threads and pull the info on what part fits what diff flange, etc. I will try to find time. http://forums.hybridz.org/showthread.php?t=66296 http://forums.hybridz.org/showthread.php?t=67761 http://forums.hybridz.org/showthread.php?t=70762 http://forums.hybridz.org/showthread.php?t=71607 http://forums.hybridz.org/showthread.php?t=71917 http://forums.hybridz.org/showthread.php?t=72269 http://forums.hybridz.org/showthread.php?t=72283 Quote Link to comment Share on other sites More sharing options...
