Guest datsun280zmike Posted February 20, 2005 Share Posted February 20, 2005 if im doing stand alone such as haltech e6k, sds or so on can i just scrap the stock wire harness? Quote Link to comment Share on other sites More sharing options...
cheftrd Posted February 21, 2005 Share Posted February 21, 2005 You can scrap the stock engine management harness, but you will want to retain some items like the oil pressure and water temp so that your stock gauges work. It's a lot easier than trying to rewire the entire car. Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted February 26, 2005 Share Posted February 26, 2005 Depends on what system you are using. On the Microtech EFI systems I sell you can use the factory Air Temp, Coolant temp, TPS and igniton moduel depending on the year of the motor you are installing. You would want to keep all those connectors to keep the install clean. Haltech and most others use GM sensors so you would have to adapt the Air temp and what not to the motor, then use the correct pigtails for that. Quote Link to comment Share on other sites More sharing options...
