Guest duende1933 Posted February 22, 2005 Share Posted February 22, 2005 Which injectors drop right into the intake manifold in the 280zx turbo engine? I got the list that has been published here and I got the Toyota Merkur (450 cc) but they did not fit. Do the holes in the manifold need to be modified to achieve fitting? Are there any that just fit right in? I'm trying to update to 450 cc size Quote Link to comment Share on other sites More sharing options...
spork Posted February 23, 2005 Share Posted February 23, 2005 I thought the merkur injectors were 370cc, not 450 Quote Link to comment Share on other sites More sharing options...
GrayZee Posted February 23, 2005 Share Posted February 23, 2005 Yes, they should be 370cc. I not sure of any upgraded injectors that just "drop right in" You have to break off the plastic pintle caps off of the tip and then just use care when inserting them to the manifold. Quote Link to comment Share on other sites More sharing options...
EZ-E Posted February 23, 2005 Share Posted February 23, 2005 Another note is that they are not Toyota Mekurs, lol, but if you look I believe at the top of this section there is a sticky of all injectors that swap into the ZXT. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted February 26, 2005 Share Posted February 26, 2005 injectors for z are called hose barb style injectors.others that will fit are bosch 0-280-150-036 (about 36lb/hour) or 0-280-150-041(45 lb/hr).036 was used in merc 450 and mercury 2.5l outboards.041 was used on merc 6.9 v8.these are not as common as they are not used on production cars anymore.been looking for them on ebay-not going to happen soon.the ford 42lb lightning truck injectors are all over ebay. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted April 11, 2006 Share Posted April 11, 2006 Although these are O-Ring tops and require an O-Ring fuel rail (Pallnet or JSK), will the lower part of these fit a stock L28 manifold? I am not sure if these Ford 42# are Low or High impedence. http://cgi.ebay.com/ebaymotors/Ford-Racing-42-pound-injectors-brand-new-mustang_W0QQitemZ8055520957QQcategoryZ33554QQrdZ1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
