looking for info LD28
rayaapp2
I am looking for a diesel injector nozzle kit that is larger than the stock setup on the LD28.
also
where do I pickup a tach signal... alt? that'll be weird
what is the exact redline of the diesel
does the maxima have an electric fuel pump other than the high pressure mechanical one.
I am looking for someone who has technical knowllege with either the maxima or the industrial counterparts with the LD28.
thanks
if you need fuel rate turned up you need to take injector pump to a diesel pump shop-there should be a shop in your area because tractors use diesel injector pumps.if you put a lot more fuel into the engine you need a pyrometer becuase an over-fueled diesel will melt itself down.if the vehicle is smoking alot of times it a an injector in poor condition with a bad spray pattern.i have had diesel vw rabbits and a 7.3 na ford pu.if you change the injector timing and fuel rate theses engines will run good if the pump and injectors are at new spec or better.i got a pump and injector set rebuilt for a rabbit for a customer because some gasoline got ran through it.car ran great-but the pump timing was advanced a little.the diesel shops have pump dynos and injector spray test equipment.
