Guest 4u2nV Posted February 24, 2005 Share Posted February 24, 2005 Hi gang, i've had my 82 280zxt for over 3 yrs now and i'm mostly convinced that putting the sbc 350 in will be cheaper for me in the long run for the power i want out of it, I just ran into a mechanic i'm building a website for and he has a sbc 350 with 12k miles on it in a blazer, just wondering if $600 is a good price for the complete engine, he said all it needs is a flywheel which is pretty inexpensive but i need to know if this is a good buy, the truck was sitting for 3 months, i went in back of his shop and turned it over and it started right up sounded great with exception to the flywheel clatter what do you guys think? should i go chevy instead of rebuilding my old l28et? thanks in advance. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted February 24, 2005 Share Posted February 24, 2005 What Blazer (year and model)..... It is likely a very good deal. Quote Link to comment Share on other sites More sharing options...
Guest 4u2nV Posted February 24, 2005 Share Posted February 24, 2005 i believe it's a 91 or maybe earlier, it's the big blazer not the little s10 i think it's a 1500 Quote Link to comment Share on other sites More sharing options...
jbk240z Posted February 24, 2005 Share Posted February 24, 2005 I would just make sure it is the flywheel before you pay. Be there when it is pulled out. A cracked flywheel will be very obvious. Does the noise quite down when put into gear? If so, it's possible to be the cause. Good luck. Does sound like a good buy if it's complete with accessories. Quote Link to comment Share on other sites More sharing options...
Guest 4u2nV Posted February 24, 2005 Share Posted February 24, 2005 yeah it's just the flywheel, also i was wondering if the transmission can be used or do i have to get a different one, cause i'm trying to stay away from chopping up the z as much as possible, it's an 82 280zxt 2+2 if that has any bearing. Quote Link to comment Share on other sites More sharing options...
jbk240z Posted February 25, 2005 Share Posted February 25, 2005 If the blazer is a 4X4 then no go on the trans. A 2wd trans could work altough I believe the tail shaft is longer than a car trans, but I think it's only 3 inches longer. You have a 2+2 model so it should work fine. Quote Link to comment Share on other sites More sharing options...
