v6 to v8 7004r bolt patterns
Guest tony78_280z
yeah i guess, if you wanna go through the hassle.
check on ebay there's a guy selling a turbo 400 bell housing.
it's after market! it will work for the application you are talking about.
also there is a guy who's selling a chluch turbo 400 that way you can see how it fit's together.
if the transmission if from a 4.3 v6 is the same pattern! the 4.3 (262) was the only one made with the same bolt pattern as the gm's v8 small and big block!
Guest TAlchemist
i thought all 700r4 trannys are 1 peice, or that you cannot change the bolt patern other than using an adapter plate. The bellhousing doesnt come off like the th350 and th400?
Guest TAlchemist
i was thinking how on the C4 and some other transmissions the front part that connects to the engine , bellhousing, can be removed to change the bolt pattern. i didnt know that the th350/400 and the 700r4 are all solid case designs with non-removeable bellhousings
