Guest steve 78 280z 2+2 Posted March 3, 2005 Share Posted March 3, 2005 I have a 78z 280z, FI, L28. Don't have manual. Any tips of removing it. I heard you need to jump wires to release fuel pressure. Any past experience would be helpful. thanks Steve 78 280z 2+2 Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted March 3, 2005 Share Posted March 3, 2005 To depressurize 280Z use this link. http://www.atlanticz.ca/zclub/techtips/fuellinedepressure/index.html Remove the 2 screws securing the valve to intake manifold and unfasten clamp and remove valve from the fuel hose. Have a small container to catch any fuel left in the fuel hose. Reverse steps to install..... LARRY Quote Link to comment Share on other sites More sharing options...
Guest steve 78 280z 2+2 Posted March 7, 2005 Share Posted March 7, 2005 thanks for the tip Larry. Changed the cold start valve with no problem, however.....Why is it still running rough in the morning? I thought the cold start valve woould solve this problem. Any tips??? steve f. Escondido, Ca Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted March 7, 2005 Share Posted March 7, 2005 If it idles rough but revs good check the bellows between the air box and the throttle body. This is metered air and any cracks in it will mess the mixture up. Take the bellows off and check for cracks and replace it if needed. LARRY Quote Link to comment Share on other sites More sharing options...
Guest steve 78 280z 2+2 Posted March 10, 2005 Share Posted March 10, 2005 o.k. I also changed my AFM, along with my cold start valve. However my MPG have gotten worse. What else do I need to adjust. With high gas prices on the rise, I need some help. thanks Steve F. Escondido, Ca Quote Link to comment Share on other sites More sharing options...
