exhaust help...
wigenOut-S30
Well since I swapped the turbo motor in my Z.. I had to use the stock Cast Iron DP.. well some of it anyways.. I cut the bottom off. I had a peice of aluminized steel brazed to it so I could get the rest of my exhaust welded on. I know its not the best of things to do..When I pulled in my driveway last night the brazing broke and my exhaust came loose from the cast iron down pipe. Doing it this way was supposed to be a temp fix until I can afford to make my mandrel stainless system.. Now.. I am kinda in a pinch.. SEZS is 2 weeks away and I am here with a open DP.. Any thoughts on welding to the cast iron DP? or anyone know where I can get the correct steel nissan T3 flange fast..? I talked with Grayzee and I plan on getting a Stainless flange from him a little later so I can start my stainless exhaust.. but for now I just need to get this put back on to make the event!.. Thanks for any help..
