Brake Upgrades
tonycharger72
If you buy a R33 half cut, try mounting the brakes from it, i have seen it done fairly easily to silvias (same bolt pattern as us). The main thing you need to do is re-drill the rotors.
Hope this helps a bit.
PS, what state are you in, I'm from Oz too, and what car is the motor going in to?
I've heard this is true if you change to Z31 Jap Spec Struts (Z31 Aussie style have different caliper mounting sizes) - this is what i've heard............
Im in Canberra, where abouts are you?
Im thinking of going with HoppersStoppers - they do a Kit for about $1300AUS for 300mm by 28mm vented/slotted front rotors from a BA Falcon, with PDR BA Falcon 2-Piston Calipers,
Comes with lines, pads, brackets, everything..........straight bolt-on
But you need to use a 1" master-cylinder with this,
They even recommend not bothering to change the rear brakes - maybe go to a larger wheel cylinder, but that is about it
