280Bob Posted March 22, 2005 Share Posted March 22, 2005 I have a few questions about choosing a wheel for my 280z. I would like to run a 16x8 wheel. I have read in some old posts that others on here are running 16x8 with 5" backspacing and a 12.7mm offset. Is this the best setup to run with stock fenders and MM coilovers? I would like to have a nice sized lip on the wheels and I am not sure if the above setup would need to be adjusted slightly to achieve this? Finally, I am installing the S12w calipers with vented rotors and I would like to know if the above setup will clear these brakes? If not, any suggestions for a more optimal setup would be appreciated. Thanks, Bob Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted March 22, 2005 Share Posted March 22, 2005 Take it down to one of the big tire shops. Have them put your car up on a rack and mount one of the wheels you want. Then you can check if everything will clear. Everyone around here will do it for free. Some may even put a tire on the wheel for you too. Quote Link to comment Share on other sites More sharing options...
jt1 Posted March 22, 2005 Share Posted March 22, 2005 I'm running 16 x 8 with 5" backspacing, with 12" spring coilovers and 245/45/16 tires. Fender lips are lightly rolled. Some people have gone a little larger on the rear, using short springs, but I like to be able to rotate my tires and wheels. Search and read some more, there's a ton of discussion on this in old posts. John Quote Link to comment Share on other sites More sharing options...
Tim240z Posted March 22, 2005 Share Posted March 22, 2005 Same as John, but with 10" coilovers and no fender rolling. Plenty of room. Quote Link to comment Share on other sites More sharing options...
