'79 Gnzx
Guest e55amg
Guest e55amg
Has anyone successfully put a GN engine in a ZX? I did a quick search and came up empty. I did a test fit this weekend to start on the motor mounts and it's T-I-G-H-T. It seems much tighter than the pics I've seen of the installs in older Z's. It looks like you have to mount it well forward to clear the downpipe. This wasn't unexpected, but it will require some major oil pan surgery. The pics of installs in older cars looks like the engine's farther behind the crossmember. Power steering is obviously out. What are my options here? What's the interchangability with older cars? How do the sizes of the boxes compare?
Thanks,
Mark
Mark,
As far as I know, you are the first person to put a GN engine into a Z car other than a 240Z. The engine in my GNZ is actually located behind the crossmember and offset 1.5" to the drivers side for downpipe clearance. I'm not familiar with the engine bay of the ZX, so I really can't help you there.
What do you mean? Parts interchangability between your '79 and the '70-'78 Z cars?
What's a "box"?
!M!
Interchangability... The z and zx came with the same engine and I believe the same mounts from engine to crossmember... So If you use the right combination of parts from someone who installed a GN into their early z, you should come up with a set of mounts that might work with only a few modifications.
-Oliver
What's a "box"?
I'm pretty sure he's talking about the steering boxes, the zx's power steering wont fit.
There were zx's made without power steering so if you can find one of those , just swap all the parts over, but if you run into fit problems with that your going to have to get inventive.
Guest e55amg
Yes, the steering box. It's going to be a real problem unless I can find something much smaller. The logical move would be a non-power box from a ZX. I was just wondering what the interchangability was with older cars.
I didn't have the transmission mounted, but it didn't look like I could offset the engine 1.5" and clear the tunnel... even if I didn't have the clearance problems with the steering. It looks like it'll have to be offset though.
I won't be able to mount the engine far enough forward to get the downpipe to clear without altering the oil pan. Did you notch the pan for the 240 install?
I have pics, but I need to post them somewhere...
Guest Aaron
The ZX's firewall is about 3 inches closer to the crossmember than the Z's.
The later ZX's (82-83 I think) had a power rack and pinion instead of a box.
Guest e55amg
Thanks. That explains part of my problem.
Know where I can find a picture of this to see if it's worth converting?
