Weird wiring woes..
Today I set out to clean up the wiring 'mess' and get all my guages/switches back in the dash. (motor shuold be done next week, want evrything ready to go) I had red wires attached to black, electrical tape 'balls' evrywhere, splices here and there and it general was a PITA. So I jumped power to the fuse panel (booster cable) and sorted all my lights out, ran new fused lines (fuel pump switch, fog lights, stereo, ect) and hooked up the hazard light switch. I had ran last year without it, cause I was to lazy to pull evryting out to get at it.. I thought this was a good time..
Anyway, it works.. but not the way it's suposed to. If I hit the switch, nothing happens. I have to hit the hazard switch AND a left or right signal, then it comes on and flashes the lights. Confused the heck out of me for a while when I was trying to sort out witch bulb was the left/right indicator in the back of the tach (I had the hazard swith on unknowingly) as they would both flash no mater what positon the arm was in! There are two relay/flasher units under the dash, and two 2 prong conectors, but only one set of wires does anything (both flasher cans do work, I checked) so I'm at a loss.. Really, I don't care much, as I have signals and hazards, it's just a weird way of working them... Any ideas?
